How LINQ Works – Where
I went digging under the surface of the LINQ query extension and iterators recently - I wanted to know how much I pay for the simplicity I get with APIs from the System.Query namespace. This post explores a little of the implementation of one of the key parts of the LINQ system. I’m starting out with the System.Query.Sequence.Where extension method because it follows on nicely from the last post on LINQ and Reflection.
An extension method is just a syntactic alternative to a normal static method that takes as its first argument a type that it will manipulate. An extension can’t do anything that a normal static method can’t, therefore we can ignore the method itself – it’s the object model that counts in LINQ, and the framework of expressions and iterators that it depends on.
I’ll start out by exploring the implementation of Sequence.Where. I will use the convention of referring to it as IEnumerable
[Extension]
public static IEnumerable<T> Where<T>(IEnumerable<T> source, Func<T, bool>predicate)
if (source == null)
throw Error.ArgumentNull("source");
if (predicate == null)
throw Error.ArgumentNull("predicate");
return Sequence.WhereIterator<T>(source, predicate);
All it does is a bit of validation before invoking Sequence.WhereIterator
<span style="color:blue;">private</span> <span style="color:blue;">bool</span> MoveNext()
<span style="color:blue;">bool</span> flag1;
<span style="color:blue;">try</span>
<span style="color:blue;">switch</span> (<span style="color:blue;">this</span>.<><span style="color:maroon;">1</span>__state)
<span style="color:blue;">case</span> <span style="color:maroon;">0</span>:
<span style="color:blue;">this</span>.<><span style="color:maroon;">1</span>__state = -<span style="color:maroon;">1</span>;
<span style="color:blue;">this</span>.<><span style="color:maroon;">7</span>__wrap2 = <span style="color:blue;">this</span>.source.GetEnumerator();
<span style="color:blue;">this</span>.<><span style="color:maroon;">1</span>__state = <span style="color:maroon;">1</span>;
<span style="color:blue;">goto</span> Label_0081;
<span style="color:blue;">case</span> <span style="color:maroon;">1</span>:
<span style="color:blue;">goto</span> Label_00A8;
<span style="color:blue;">case</span> <span style="color:maroon;">2</span>:
<span style="color:blue;">goto</span> Label_007A;
<span style="color:blue;">default</span>:
Label_003F:
<span style="color:blue;">this</span>.<element><span style="color:maroon;">5</span>__<span style="color:maroon;">1</span> = <span style="color:blue;">this</span>.<><span style="color:maroon;">7</span>__wrap2.Current;
<span style="color:blue;">if</span> (!<span style="color:blue;">this</span>.predicate(<span style="color:blue;">this</span>.<element><span style="color:maroon;">5</span>__<span style="color:maroon;">1</span>))
<span style="color:blue;">this</span>.<><span style="color:maroon;">2</span>__current = <span style="color:blue;">this</span>.<element><span style="color:maroon;">5</span>__<span style="color:maroon;">1</span>;
<span style="color:blue;">this</span>.<><span style="color:maroon;">1</span>__state = <span style="color:maroon;">2</span>;
<span style="color:blue;">return</span> <span style="color:maroon;">true</span>;
Label_007A:
Label_0081:
<span style="color:blue;">if</span> (<span style="color:blue;">this</span>.<><span style="color:maroon;">7</span>__wrap2.MoveNext())
<span style="color:blue;">goto</span> Label_003F;
<span style="color:blue;">if</span> (<span style="color:blue;">this</span>.<><span style="color:maroon;">7</span>__wrap2 != <span style="color:blue;">null</span>)
<span style="color:blue;">this</span>.<><span style="color:maroon;">7</span>__wrap2.Dispose();
Label_00A8:
flag1 = <span style="color:maroon;">false</span>;
fault
((IDisposable) <span style="color:blue;">this</span>).Dispose();
<span style="color:blue;">return</span> flag1;
Under the label Label_003F the predicate passed to Where is invoked on the current item. If the result is false, the iterator jumps to Label_0081 where it skips forward one place, before going back to check the predicate again. So in essence the iterator came from something like this:
<span style="color:blue;">foreach</span> (T val <span style="color:blue;">in</span> collection)
<span style="color:blue;">if</span>(predicate(val))
<span style="color:blue;">yield</span> <span style="color:blue;">return</span> val;
Aside from noting the foreach syntax’s brevity, we can also see that the efficiency of the Where method is directly related to the efficiency of the iterator of the underlying collection class. Every item in the collection has to be visited, and compared before the WhereIterator can decide whether to yield it to the caller. That means that in large collections where the time to iterate the whole collection is significant, Where’s filtering capabilities are not guaranteed to speed up your iterations. I say not guaranteed, as though there might be cases where that’s not the case, because there are two Where extensions and it all depends on the capabilities of the iterator on the collection we are filtering. Another extension method (System.Query.Queryable.Where) extends the IQueryable
IEnumerable
[Extension]
<span style="color:blue;">public</span> <span style="color:blue;">static</span> IQueryable<T>Where<T>(IQueryable<T> source, Expression<Func<T, <span style="color:blue;">bool</span>>>predicate)
<span style="color:blue;">if</span> (source == <span style="color:blue;">null</span>)
<span style="color:blue;">throw</span> <span style="color:blue;">new</span> ArgumentNullException(<span style="color:maroon;">"source"</span>);
<span style="color:blue;">if</span> (predicate == <span style="color:blue;">null</span>)
<span style="color:blue;">throw</span> <span style="color:blue;">new</span> ArgumentNullException(<span style="color:maroon;">"predicate"</span>);
<span style="color:blue;">return</span> source.CreateQuery<T>(Expression.Call(((MethodInfo) MethodBase.GetCurrentMethod())
.MakeGenericMethod(<span style="color:blue;">new</span> Type[] { <span style="color:blue;">typeof</span>(T) }), <span style="color:blue;">null</span>, <span style="color:blue;">new</span> Expression[] {
source.Expression, predicate }));
There’s a lot more going on here than in the case of IEnumerable
<span style="color:blue;">public</span> <span style="color:blue;">static</span> MethodCallExpression Call(MethodInfo method, Expression obj, IEnumerable<Expression>parameters)
ReadOnlyCollection<Expression> collection2 = ReadOnlyCollectionExtensions.ToReadOnlyCollection<Expression>(parameters);
Expression.ValidateCallArgs(method, obj, collection2);
<span style="color:blue;">return</span> <span style="color:blue;">new</span> MethodCallExpression(ExpressionType.MethodCall, method, obj, collection2);
The first thing it does is create a read-only collection out of the parameters – which in this case are the Expression from the source query, and the predicate object that is passed to the Where method to begin with. This collection is then validated. Finally a new MethodCallExpression is created out of a new generic method, and the collection of params created previously. The generic method is created in a subclass of MethodBase in System.Reflection. It creates a method that has a type parameter of type T (i.e. whatever type we were dealing with in the IQueryable
At this point we have created a new Expression object with a new root of type MethodCallExpression. It has branches that are the reference to the initial Expression passed as a parameter to the Where method and the predicate that we plan to use later on. Interestingly the Expression.Call method takes a parameter called obj that is not used in this case. You might have expected it to be passed the initial Expression as this parameter since that argument calls for an Expression, but instead the original expression is stored as an element in the parameters collection of the new root node.
**Figure 1. The New Expression tree created by a call to Queryable.Where **
It’s just added a node to an expression tree, and done no iteration at all. This is why Queryable.Where is so different from the first extension on IEnumerable
Next time, I’ll show you how the iteration works on normal Sequences such as we might get from reflection, and we’ll take a peek at how things work in the case of DLINQ (LINQ to SQL). In DLINQ a lot of ORM intelligence is hidden under the hood of the iterator and the Expression tree. We’ll see that the beauty of LINQ is that it manages to cleanly encapsulate the technology we need to get to the data we’re working with. As I said in a previous post, it’s vitally important to creating robust and maintainable code.
